also, in the future, please send such questions to the mailing list.
we prefer you use the mailing list because it reduces duplication and
allows the entire community to answer questions in a publicly viewable
and searchable way.
thanks,
yaw
On Tue, Mar 22, 2011 at 10:35, Richard Hurst wrote:
I unzipped the 0.9 build from your site and clicked run on the
uploadaggregatetoappengine for windows and it brings up a box for 2 seconds
then goes without asking for app engine log in or anything else! I am now
stuck, please help!
On Mar 22, 5:42 pm, Yaw Anokwa wrote:
> hi richard,
> as specified athttp://opendatakit.org/use/aggregate, you need to make
> sure you have java 6 installed. please confirm you do.
> and searchable way.
> thanks,
> yaw
> > stuck, please help!
> hi richard,
> and searchable way.
> thanks,
> yaw
> > stuck, please help!
and searchable way.
Probably the easiest thing to do is open a cmd window and run 'java
-version' as this will tell us a lot about your paths and version.
To do this simply go to the start menu and select run. In the Run
popup type "cmd". When the command prompt window comes up simply time
"java -version". Paste the response into this email thread and it
should help us to determine what is wrong.
Cheers,
Waylon
On Tue, Mar 22, 2011 at 11:28 AM, Mitch Sundt wrote:
> Hi Richard,
> What operating system are you using, and what Java version do you have
> installed, and do you have the JRE or the JDK installed?
> Mitch
> On Tue, Mar 22, 2011 at 10:59 AM, Richard Hurst wrote:
>> I do have Java 6
>> > hi richard,
>> > and searchable way.
>> > thanks,
>> > yaw
>> > > seconds
>> > > now
>> > > stuck, please help!
> Mitch Sundt
> Software Engineer
> http://www.OpenDataKit.org
> University of Washington
> mitchellsundt@gmail.com
On Mar 22, 6:28 pm, Mitch Sundt wrote:
> Hi Richard,
> Mitch
> On Tue, Mar 22, 2011 at 10:59 AM, Richard Hurst < pubandretailconsulta...@googlemail.com> wrote:
> > I do have Java 6
> > > hi richard,
> > > and searchable way.
> > > thanks,
> > > yaw
> > seconds
> > now
> > > > stuck, please help!
> Mitch Sundt
> Software Engineerhttp://www.OpenDataKit.org
> mitchellsu...@gmail.com
Please also confirm that after downloading the zip file, you right-clicked
'ODK_AggregateDeploy_v0.9.5.zip' and chose 'Extract All...', extracted the
contents to a folder, then browsed to that folder and double-clicked the
'uploadAggregateToAppEngine' script from that folder.
If you just browse into the zip file (by double-clicking into it), and try
to run the script from within the zip, the script will flash and fail as you
describe.
On Tue, Mar 22, 2011 at 11:44 AM, W. Brunette wrote:
Richard,
and searchable way.
seconds
am
Sorry for the confusion -- if you have extracted to, say, 'MyODKExtract',
the file you want to double-click is 'MyODKExtract\ODKAggregateDeploy
v0.9.5\uploadAggregateToAppEngine'
And to be clear about extracting: After the download of the file, rather
than choose "Open file", choose "Open Containing Folder" or open a
'Computer' window (aka Windows Explorer) and browse to your Downloads
directory; the downloaded zip file should be there. You should then
right-click on it, and choose the 'Extract all...' and proceed as I
described.
On Tue, Mar 22, 2011 at 1:54 PM, Richard Hurst < pubandretailconsultants@googlemail.com> wrote:
make
viewable
There is no 'ODK_AggregateDeploy_v0.9.5.zip' once the first zip file
is opened, only a non zip file which doesn't come with an extract all
option.
> describe.
> Mitch
> > Richard,
> > Cheers,
> > Waylon
> > > Hi Richard,
> > > Mitch
> > >> I do have Java 6
> > >> > hi richard,
> > >> > and searchable way.
> > >> > thanks,
> > >> > yaw
> > >> > > seconds
> > am
> > >> > > now
> > >> > > stuck, please help!
> > > Mitch Sundt
> > > Software Engineer
> Mitch Sundt
when extracting it warns that there are duplicate files with the same
name and all I can do is skip these which includes the file I need!
any chance you can send me the correct file I need so that I can just
install that element and get the form onto my android tablet?
> described.
> Mitch
> On Tue, Mar 22, 2011 at 1:54 PM, Richard Hurst < pubandretailconsulta...@googlemail.com> wrote:
> > I am using vista
> > > Hi Richard,
> > > Mitch
> > > > I do have Java 6
> > > > > hi richard,
> > make
> > viewable
> > > > > and searchable way.
> > > > > thanks,
> > > > > yaw
> > > > seconds
> > am
> > > > now
> > > > > > stuck, please help!
> > > Mitch Sundt
> Mitch Sundt
