I have been using Briefcase via CLI since the CLI was introduced. I haven't had any problems with it until yesterday when I used Briefcase 1.11.1. I upgraded from v1.10.0. I took note of the new syntax for CLI and have applied it to pull data from a test ODK server (on ONA) that I use. Server settings are as follows:
url: https://odk.ona.io
username: validtrial
password: zEF-STN-5ze-qom
I used the following command line input to try to pull from this aggregate server:
java -jar ODK-Briefcase-v1.11.1.jar --pull_aggregate --form_id stakeholders --storage_directory ~/Desktop --aggregate_url https::/ona.io/validtrial --odk_username validtrial --odk_password zEF-STN-5ze-qom
I get the following error on terminal:
Unexpected error in Briefcase. Please review briefcase.log for more information. For help, post to https://forum.getodk.org/c/support
The briefcase.log contains the following:
2018-06-28 06:40:44,573 [main] ERROR org.opendatakit.common.cli.Cli - Error
java.io.UncheckedIOException: java.nio.file.NoSuchFileException: /Users/ernest/Desktop/ODK Briefcase Storage/cache.ser
at org.opendatakit.briefcase.reused.UncheckedFiles.createFile(UncheckedFiles.java:133)
at org.opendatakit.briefcase.util.FormCache.setLocation(FormCache.java:80)
at org.opendatakit.briefcase.util.FormCache.from(FormCache.java:54)
at org.opendatakit.briefcase.operations.PullFormFromAggregate.pullFormFromAggregate(PullFormFromAggregate.java:66)
at org.opendatakit.briefcase.operations.PullFormFromAggregate.lambda$static$0(PullFormFromAggregate.java:53)
at org.opendatakit.common.cli.Cli.lambda$run$4(Cli.java:126)
at java.lang.Iterable.forEach(Iterable.java:75)
at org.opendatakit.common.cli.Cli.run(Cli.java:123)
at org.opendatakit.briefcase.Launcher.main(Launcher.java:79)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)
Caused by: java.nio.file.NoSuchFileException: /Users/ernest/Desktop/ODK Briefcase Storage/cache.ser
at sun.nio.fs.UnixException.translateToIOException(UnixException.java:86)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102)
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107)
at sun.nio.fs.UnixFileSystemProvider.newByteChannel(UnixFileSystemProvider.java:214)
at java.nio.file.Files.newByteChannel(Files.java:361)
at java.nio.file.Files.createFile(Files.java:632)
at org.opendatakit.briefcase.reused.UncheckedFiles.createFile(UncheckedFiles.java:131)
... 13 common frames omitted
2018-06-28 08:41:11,678 [main] ERROR org.opendatakit.common.cli.Cli - Error
When I use version 1.9.0 of Briefcase, command produces no error and expected results are produced.
ODK Briefcase v1.11.1 .jar file on a macOS 10.13.5
Steps described above. Details of server being accessed available above.
I tried both the long form and the short form of the CLI syntax.
