I created a survey with choices and external choices. Trying to use external choices with a filter for district, commune, fokontany. When i upload to any converter I get a list_name error
I tried converting using these tools:
changed the list name in both my survey and external choice sheets
You have a couple of issues in your form, first start by correcting the choice filter column, it needs to be choice_filter . In other select one options put a space, and remove spaces in the xls file name.
Your choices for commune have issue, there is a mistake there , this Alaotra Mangoro is a region, yet in commune, the filter column is in district column. Commune does not come up because you mixed the region and district in external choices sheet.
