I need to modify javarosa code to complete my android based mobile app
requirement. I have downloaded javarosa code from "
https://bitbucket.org/javarosa/javarosa/src/tip/core/ ". After updating
code, just create a jar file by following "
docs.oracle.com/javase/tutorial/deployment/jar/build.html " url. But,
odk-collect cannot detect any package from javarosa jar(which is located in
lib folder). Now, i don't what can i do. Note: my creating jar is added.
javarosa-libraries.jar (343 KB)
You should use the https://bitbucket.org/m.sundt/javarosa repo to
build. It has the most up-to-date code that we use in ODK.
You will need to put some dependencies in the /lib folder. Download
them from https://bitbucket.org/javarosa/javarosa/downloads.
In the /core folder, there is a build.xml file. Run ant there to build
the javarosa-libraries.jar you need.
Move javarosa-libraries.jar to the /libs (not /lib) folder in your Collect repo.
If IDE does not recognize the jar automatically, then you might have
to play around with its settings (or the .classpath settings)
Need ODK services? http://nafundi.com provides form design,
professional support, custom reporting, and software development for
ODK.
Thank you so much for your response. it's very helpful for me and i can
solve my problem by following your solution.
