I am currently setting up a robot to perform scheduled "pulling" of surveys
from ODK Briefcase by using keyboard instructions (eg Tab, Enter, Spacebar
etc). I am able to connect, select the forms needed but i then cannot get
to the pull button using "Tab" as it stays within the list of forms. Is
there a shortcut i can use to push the "pull" button or some other way of
navigating to it by only using keyboard strokes?
etc). I am able to connect, select the forms needed but i then cannot get to
the pull button using "Tab" as it stays within the list of forms. Is there a
shortcut i can use to push the "pull" button or some other way of navigating
surveys
Spacebar
get to
there a
navigating
