Using central as backend and collect as frontend.
Delay in keystrokes is being faced while typing in text box of a survey.
Please guide how can I speed up or do it normal as in other applications.
Could trace the issue. The linked drop down list contains more than 1000 options. This is creating a problem of keystroke lag in collect app.
However, tried the separate xml file option using external select. But nothing works as of now.
Hi @rameshbhalla81, I'm sorry to hear about your challenges. Are you able to share the form file here? Also, what are the specifications of the device you're using? The phone's RAM, Android version, Collect app version, etc.
