I am sure this is fairly simple but it is not working for me.
I have a question that asks the registration number of the business being
surveyed - The registration number is always 11 characters.
In order to enable it to only accept answers of this length I put
constraint=" . >=9999999999 and .<999999999999"
but no matter what is entered it tells me that the answer is not allowed.
I also have this same issue with a constraint applied for a month entry
where I want to obviously limit it to under 12 months as I´m giving them
the option to say that they have worked for x years and y months.
Integers can't be bigger than 2,147,483,648. Instead, make a text
prompt with an appearance attribute of "numbers" and a constraint of
"regex(., ^[0-9]{11}')". https://code.google.com/p/opendatakit/issues/detail?id=546 has an example.
As to the month constraint, not sure what is going on. Maybe make sure
you are using an integer prompt (and not date). If you are using the
date prompt, I don't know offhand how to do that constraint. Maybe
someone else from the community can look that up.
where I want to obviously limit it to under 12 months as I´m giving them the
