Hi all,
Is it possible to limit accuracy of location? Currently in my device it
automatically stops at 5m.
Thank you
Prakash
Hi all,
Thank you
Prakash
Hi Prakash,
The solution to your problem is described at
http://opendatakit.org/help/form-design/examples/ under Geo-location
Prompts
By default, the widget halts the geo-positioning process once the
geopoint has an accuracy of 5m or less. To change this, you can supply
an "accuracyThreshold" attribute to the tag. I.e., to instruct
ODK Collect to capture geopoints with accuracies of 1.5m or less, use:
<h:body>
geopoint widget
this will get gps location
</h:body>
On Wed, Mar 19, 2014 at 10:59 PM, PS PRAKASH psprakashgis@gmail.com wrote:
Hi all,
automatically stops at 5m.Thank you
Prakash--
Thank you Yaw.
