(1) Use ODK Briefcase to pull the data down to your computer, then export
it into multiple CSVs, one for the overall survey and for each repeat group.
or
(2) set up a publisher into Fusion Tables and use the synthesized view that
joins the repeat groups and main survey into a very wide table of extended
records.
On Tue, Jun 7, 2016 at 4:23 AM, wrote:
Hello,
Exported CSV files include a link instead of the actual data collected
using Loops/ Repeats.
The loops did work and data were collected correctly using ODK Collect.
How can I get the data for onward use in a spreadsheet/ database?
