I have downloaded the ODK Collect and managed to run in an emulator and real device which is working perfectly fine. But when i tried to make changes in the code it doesn't seems to be working. No changes taking place in the device. I have tried text changes and layout changes as well, but nothing seems to be changing.
What i am doing wrong here?.
Sorry you are having problems. It's likely the issue is with your dev
setup. Try refresh and a clean build of the source. Make sure the
changes are actually compiling and getting pushed to the device. If
that fails, try getting Hello World running
(http://developer.android.com/training/basics/firstapp/index.html) and
see if you make changes there.
