Making ODK Aggregate VM Accessible from outside
Hi All,
I have setup ODK Aggregate VM on my local server and I want to be able
to access it from other networks. Any instructions on how this can be done?
Kind regards,
Mofya
Mofya,
To do this, you have to make your VM publicly accessible on the
Internet with a static IP or fully-qualified domain name. Doing this
requires a fair amount of technical skill and I instead recommend you
use Aggregate on App Engine or do install Aggregate on a normal
Tomcat/MySQL server.
··· -- Need ODK help? Go to http://nafundi.com for custom features, form design, implementation support, and user training for ODK.
On Fri, Jul 12, 2013 at 12:53 AM, Mofya Phiri mofya1@gmail.com wrote:
Hi All,
I have setup ODK Aggregate VM on my local server and I want to be able to
Kind regards,
Mofya
--- You received this message because you are subscribed to the Google
Groups "ODK Community" group.
More details on the steps are here:
http://opendatakit.org/use/aggregate/tomcat-install/#Configure_for_Network_Access
In addition what is described there, since the VM is Linux, you also would
need to understand how to make any appropriate changes on Linux.
As Yaw says, if you are not tech-savvy, do not have an IT/network
specialist to help you, or do not have the time to become very
knowledgeable yourself, we would recommend against attempting this.
Troubleshooting network configuration problems, by its nature, has to be
done on site.
··· On Fri, Jul 12, 2013 at 7:29 AM, Yaw Anokwa wrote:
Mofya,
Hi All,
Kind regards,
Mofya
