"map it" doesn't work on localhost
Hello,
I have installed odk on a localhost, with tomcat and mysql. It all works, but the function "map it" doesn't work. The map shows, but no pointers. The "pie it" and "bar it" do work.
Is this because I use mysql? Should I use Postgresql instead? Or is there something else wrong?
This works fine for me.
Does your dataset contain geopoints? (the data type geopoint) And did you
select one of these for the location to plot?
Try capturing data with the Geo Tagger v2 form (attached) and see if MapIt
works on that form (this is what I test with).
Geo Tagger v2.xml (1.03 KB)
ยทยทยท On Tue, Feb 3, 2015 at 5:11 AM, steven wrote:
Hello,
