Hey there,
I'm using the fuzzy lookup application for aligning data from Kobo. I am
wondering if you have any suggestions for matching a repeat inside another
repeat before matching to the main data.
So I have:
Main Data
Repeat
Repeat inside Repeat
-B
This is not the support list for the Kobo server. You should ask questions
about Kobo on their list.
Fuzzy lookup is avoided by design in ODK Aggregate (each addition or
deletion of a question in a survey results in a distinctly different form).
The burden is then on the data analyst to reconcile the data from those
different forms. At that stage you would want tools that can mutate those
different forms into one consolidated data set for analysis (but, at the
time you do that, you are fully aware of what form definition was used to
generate that submission, so there is no guesswork or fuzzy reasoning
required to determine where you are coming from and what you need to
examine or adjust).
On Wed, Aug 24, 2016 at 8:52 AM, Brett Collins wrote:
Hey there,
So I have:
Main Data
Repeat
-B
