is there a maxmum number of questions in a repeat group 2. What app or server are you using and on what device and operating system? Include version numbers.
whe I remove some questions from the repeat the form uploads fine on aggregate, however when i add them it stops 4. What steps can we take to reproduce the problem?
With the validator it passes through and converts to XML using that online converter, however it's the converted XML file that refuses to upload onto odk aggregate, when I upload other files they are pkay
Your XML file refused to upload because it contains errors, The xlsform validator will help you locate those errors. One of the error show is this *"Error: There has been a problem trying to replace ${mtmem10} with the XPath to the survey element named 'mtmem10'. There is no survey element with this name."
I have tried clearing all errors and now validate shows no error, however aggregate is still bouncing I just don't when where am going wrong that validate can't catch yet aggregate gets
