Hi -
I am trying to figure out the correct syntax for calculating the minimum of a set of values that are calculated using if/then/else logic and I keep getting NaN when I use min(nodeset).
This is what I currently have set up:
- value 1, value 2, ... , value 6 are all stored as calculate fields with the constraint to store as a number
- the field mon_reg_string concatenates value 1 through value 6 into a string (value 1, value2, ... , value6)
- the final field, mon_reg, calculates min(mon_reg_string)
When I display mon_reg, I show NaN.
Any suggestions on how to store the minimum of these 6 calculated values and then display? If this cannot be done, I would have to resort to a manual entry of the lowest score after displaying all 6 values and would open the form up to a data entry error.
Vina
Hi Vina,
It'd help if you could provide the XML of a form with just these
prompts so others could help track down the issue.
Need ODK services? Go to http://nafundi.com for form design, data
cleaning, custom reporting, and software development for ODK.
On Tue, Jul 16, 2013 at 11:21 AM, vina.chhaya@gmail.com wrote:
Hi -
Vina
Good point - sorry, I am new to this. Here it is:
value 1:
value 2:
value 3:
value 4:
value 5:
value 6:
concatenating all values into a string:
calculating min and display of min:
<input ref="/SMS_16July_2/Monitoring/Registers/mon_reg_display">
<label>Score for 9.1 Register Score (lowest) is: <output value="/SMS_16July_2/Monitoring/Registers/mon_reg_string"/></label></input>
On Tuesday, July 16, 2013 4:00:35 PM UTC-4, Yaw Anokwa wrote:
> Hi Vina,
> Yaw
> On Tue, Jul 16, 2013 at 11:21 AM, wrote:
> > Hi -
> > Thanks,
> > Vina
Sorry, the score display output value was wrong below. It should be mon_reg and not mon_reg_string:
<label>Score for 9.1 Register Score (lowest) is: <output value="/SMS_16July_2/Monitoring/Registers/mon_reg"/></label></input>
> value 1:
> value 2:
> value 3:
> value 4:
> value 5:
> value 6:
> > Hi Vina,
> > Yaw
> > > Hi -
> > > Thanks,
> > > Vina
Vina,
What I meant was a complete but small (say a three question) XForm
that has the problem.
value 1:
value 2:
value 3:
value 4:
value 5:
value 6:
<bind nodeset="/SMS_16July_2/Monitoring/Registers/mon_reg_display" readonly="true()" relevant="selected(/SMS_16July_2/st_cc,'9')" type="string"/>
Hi Vina,
Hi -
Vina
Here are the example lines. Let me know if anyone can help! The min function does not appear to work. Thanks!
On Tuesday, July 16, 2013 4:55:06 PM UTC-4, Yaw Anokwa wrote:
> Vina,
> Yaw
> >> value 1:
> >> value 2:
> >> value 3:
> >> value 4:
> >> value 5:
> >> value 6:
> >> > Hi Vina,
> >> > Yaw
> >> > > Hi -
> >> > > Thanks,
> >> > > Vina
Hi Vina,
I've filed this at
https://code.google.com/p/opendatakit/issues/detail?id=878 for the
core team to track down. Please star that issue to get updates.
Vina,
value 1:
value 2:
value 3:
value 4:
value 5:
value 6:
Hi Vina,
Hi -
Vina
This is not an error in JR -- the min() and max() functions are only valid
for numeric values.
These need to be type="int" or type="decimal"
On Tue, Jul 23, 2013 at 4:24 PM, Yaw Anokwa wrote:
Hi Vina,
I've filed this at
(lowest) is:
Vina,
<input
value 1:
value 2:
value 3:
value 4:
value 5:
value 6:
<bind
type="string"/>
<input
Hi Vina,
Hi -
Vina
