hi there,
There is any way to modify the question text of a given question from
ODK-Collect?
It seems the text displaying is done by javarosa, and I can see a
FormEntryPrompt.getQText() method with no setter. The same happens with
FormEntryPrompt.getQuestion() where I can't modify the text. I was wondering
whether it's allowed to modify such text from ODK-Collect or I should go
deeper inside javarosa..
thanks in advance,
pau.
haven't looked at the javarosa-core in sometime, but i'm pretty sure you can't
modify question text. why do you need this functionality?
On Mon, May 16, 2011 at 06:39, Pau Varela wrote:
> hi there,
> ODK-Collect?
> thanks in advance,
> pau.
if you want dynamic question text, use
can't
On Mon, May 16, 2011 at 06:39, Pau Varela pau.varela@gmail.com wrote:
hi there,
ODK-Collect?
wondering
thanks in advance,
pau.
Thanks for your replies,
we've coded some forms in Farsi, but utf-8 shows the text character by
character, without connecting the letters.. I need to transform the text
with some java code prior to display it in odk..
Drew, I understand is there replacement for the tag...
(pretty obvious
How would you access it? and what about and
fields? would it be possible to also modify their question text
and label values?
pau.
2011/5/16 Drew Roos
can't
hi there,
ODK-Collect?
wondering
thanks in advance,
pau.
if you need to transform text in that way, i'd look deep into the core
where the parsing takes place. the alternative (easier to code but
less efficient) is to do that transform every time you display
question text.
you can put output in labels. so for example,
confirm your name is ?
> (pretty obvious ;) How would you access it? and what about and
> and label values?
> pau.
> 2011/5/16 Drew Roos
>>> can't
>>> > hi there,
>>> > ODK-Collect?
>>> > wondering
>>> > go
>>> > thanks in advance,
>>> > pau.
i didn't think was supported anywhere other than question captions.
clayton tells me otherwise, so it might work, but i'd say be wary.
in general, any problem with utf-8 text rendering is outside the scope of
the application, and the responsibility of the underlying platform.
if you're already modifying code, you can hook into running arbitrary code
during an xform session by creating and registering a custom xpath function
handler. this would only help you inasmuch where you can use ,
though.
(pretty obvious
and label values?
pau.
2011/5/16 Drew Roos droos@dimagi.com
can't
hi there,
ODK-Collect?
wondering
go
thanks in advance,
pau.
Ok, thanks again.
I'm not sure output option would work, because we do have already the text
within the xform and it's precisely what needs to be transformed.
As for the xpath function handler, I understand I should implement an
IFunctionHandler class, which receives an XPathNodeset, but I thought that
was to deal with values, not with the text descriptions.. at least this is
the way I used it in the past.. Am I right with this assumption?
As Yaw suggest, I'll try to investigate where the parsing is done and see
what I can do in there... I just wanted to be sure there was no option from
ODK before getting crazy with javarosa...
pau.
2011/5/16 Drew Roos
captions. clayton tells me otherwise, so it might work, but i'd say be wary.
though.
tag... (pretty obvious
and fields? would it be possible to also modify their question
text and label values?
pau.
can't
hi there,
ODK-Collect?
with
wondering
go
thanks in advance,
pau.
