You can add deviceID and userID to your form. If you are using
XLSForm, see the metadata section on http://opendatakit.org/help/form-design/xlsform/ for a how to. Then
when you download your data or build your reports, you can order by
deviceID or userID to see the counts.
By the end of the report generation from the Smartphone app, can a
sentence could be generated based on each selection? For example: first
step: traffic congestion, second step: northeast, third step: stand still
(congestion level), forth step: car fire (congestion reason), fifth step: A
1 (road), sixth step: 10 mins (waiting time). Then a sentence like this
could be generated before submit to the web server, "traffic
congestion northeast
stand still caused by car fire at A1 waiting 10 mins".
If Smartphone app could not do this, after a report is submitted to web
server, can web server do this? Combine each lab to a sentence?
[image: Inline images 1]
I'm looking forward to your reply. I'll be grateful with your help.
By the end of the report generation from the Smartphone app, can a sentence could be generated based on each selection? For example: first step: traffic congestion, second step: northeast, third step: stand still (congestion level), forth step: car fire (congestion reason), fifth step: A 1 (road), sixth step: 10 mins (waiting time). Then a sentence like this could be generated before submit to the web server, "traffic congestion northeast stand still caused by car fire at A1 waiting 10 mins".
If Smartphone app could not do this, after a report is submitted to web server, can web server do this? Combine each lab to a sentence?
first
still
step: A
this
congestion
There's no easy way to get road name based on a geopoint.
If there are very small number of geopoints and you are using Collect
1.4.3 I could imagine a form that converts a geopoint to a string and
then uses that as a lookup in an external itemset where you've put the
geopoint to road links.
I've never tried this, can't spend time trying it, and I'm pretty sure
it's a bad idea. But, it's your best shot if you don't want to
customize ODK Collect with Java code.
first
still
step: A
this
congestion
to
Thanks for your comments and suggestions. Another question,
I set geopoint accurate should be less than 5 meters. I found that it does
not perform very well when recording the geopoint every time, not just the
first time. I also found that around different indoors, the geopoint performs
different as well. Some where, it could get the location very fast, but other
place, it could not get the data.
Can I set geopoint as the default metadata when loading the form?
Weatherit could run at the backstage automatically?
Best Regards,
Weijia
On 21 March 2014 21:14, Yaw Anokwa wrote:
Weijia,
can a
first
still
step: A
this
congestion
to
Then
by
performs different as well. Some where, it could get the location very fast,
but other place, it could not get the data.
Can I set geopoint as the default metadata when loading the form? Weather it
can a
first
stand
still
fifth
step: A
this
congestion
submitted
to
sentence?
help.
Then
by
does
the
fast,
Weather it
can a
example:
first
stand
still
fifth
step: A
like
this
congestion
submitted
to
sentence?
help.
using
Then
order
by
does
the
fast,
Weather it
can a
example:
first
stand
still
fifth
step: A
like
this
congestion
mins".
submitted
to
sentence?
help.
using
Then
order
by
SatNav performance is based on the quality of the radio, and a clear line
of sight of the sky, without anything that would block or cause the signal
to bounce off.
If you are collecting tracks, you're probably better off using a dedicated
tracking app rather than Collect. I does make me wish Collect can support
"attachments", so I could make a track part of a form record.
On Sunday, March 23, 2014, Yaw Anokwa wrote:
Weijia,
Don't know, but depends on the GPS. Perhaps you can try it out on
your device and report back to the community.
Not unless you write code to do this.
does
the
fast,
Weather it
the
sure
does
the
fast,
Weather it
the
sure
app,
can a
example:
first
stand
still
fifth
step: A
like
this
congestion
mins".
submitted
to
sentence?
help.
using
to.
Then
order
by
does
just
the
very
fast,
Weather it
Collect
and
the
sure
app,
can a
example:
first
step:
stand
still
reason),
fifth
step: A
sentence
like
this
congestion
mins".
submitted
to
sentence?
your
help.
using
to.
Then
order
by
What do you mean a track part of a form record? Do you mean track GPS from
A to B?
Weijia
On 25 March 2014 00:40, ゴー・ニコライ wrote:
Weijia,
to bounce off.
does
just
the
very
fast,
Weather it
Collect
and
the
sure
I do not want anonymous users to visit all the met data, I just want
them to visit the calculate section and only visualise the geopoint on the
map to anonymous users.
How can I let reporters to see their contributions? For example: how
many they report and when they report? Meanwhile, apart their own data,
other data they only can see the calculate data as well like the anonymous
users and only visualise the geopoint on the map as well.
Best Regards,
Weijia
On 25 March 2014 13:53, Yaw Anokwa wrote:
Weijia,
If you want GPX tracks attached to a form, you'll have to write code
(in Collect, XLSForm, Aggregate, etc) to support that.
it
does
just
the
geopoint
very
fast,
Weather it
Collect
and
the
sure
server
app,
can a
example:
first
step:
stand
still
reason),
fifth
step: A
sentence
like
this
"traffic
congestion
mins".
submitted
to
sentence?
your
help.
are
using
how
to.
Then
can
order
by
I do not want anonymous users to visit all the met data, I just want them
to visit the calculate section and only visualise the geopoint on the map to
anonymous users.
it
does
just
the
geopoint
very
fast,
Weather it
Collect
and
put
the
sure
server
Smartphone
app,
can a
example:
first
step:
stand
still
reason),
fifth
step: A
sentence
like
this
"traffic
congestion
mins".
submitted
to
sentence?
your
help.
are
using
how
to.
Then
can
order
by
them
map to
anonymous users.
anonymous
that
it
does
not
just
the
geopoint
location
very
fast,
form?
Weather it
Collect
string
and
put
the
pretty
sure
server
Smartphone
app,
can a
For
example:
first
step:
stand
still
reason),
fifth
step: A
sentence
like
this
"traffic
congestion
10
mins".
is
submitted
to
to a
sentence?
with
your
help.
you
are
using
a
how
to.
Then
can
order
by
