I am working on various custom analog scale widgets for a client that
requires multiple user-editable label segments to be added to an integer
question. One of the things this project needs to solve might very well be
relevant to something you have encountered or may encounter in the future.
Therefore, I wanted to see if you have any feedback.
The solution I am thinking of is pretty simple. Put all text inside a
single [label] but use a pipe | separator, e.g.
This is the main label | This is the sub label | Text for top of
scale | Text for bottom of scale
If somebody has solved this requirement previously, I would probably prefer
to adopt that solution, so please let me know. Otherwise, any thoughts
about this approach?
Do you have a sketch of how this will look like in a UI for the
top/bottom of the scale?
What happens if you want to represent something like a likert scale?
On Wed, Sep 9, 2015 at 4:16 PM, Martijn van de Rijdt martijn@enketo.org wrote:
Hi ODK Devs,
The solution I am thinking of is pretty simple. Put all text inside a single
to adopt that solution, so please let me know. Otherwise, any thoughts about
this approach?
Yes, it could be done in hints as well. That might be better maybe
depending on the semantics of the 4 pieces of text. Thanks!
Only this particular widget (and possible future ones) will look for the
text separator and split the label (and/or hint) to extract the 4 different
parts. A likert widget will just not look for the separator and continue to
have only one label and one hint.
Cheers,
Martijn
On Fri, Sep 11, 2015 at 6:43 AM, Yaw Anokwa wrote:
Martijn,
Hints are already sub-labels. Why not use hints?
Hi ODK Devs,
be
future.
single
prefer
about
this approach?
Every time I've done this sort of thing, it's ends up being fragile.
For that reason, I don't love putting separate labels in the same
slot.
That said, I can't think of a better alternative. Maybe key:value
pairs (e.g., topLabel, bottomLabel) as attributes on the node?
On Fri, Sep 11, 2015 at 12:16 PM, Martijn van de Rijdt martijn@enketo.org wrote:
Thanks Yaw,
Yes, it could be done in hints as well. That might be better maybe depending
Hi ODK Devs,
be
future.
single
prefer
about
this approach?
Yes, I agree. Multiple labels or non-main-level-label attributes would be a
more solid way of going about this.
slot.
Thanks Yaw,
depending
different
to
On Wed, Sep 9, 2015 at 4:16 PM, Martijn van de Rijdt < martijn@enketo.org> wrote:
Hi ODK Devs,
integer
well
be
future.
single
of
prefer
about
this approach?
