This is fine except that when I now choose the language within the form I have four options, the English and Malagasy from the label and hint columns which don't show any language for constraint messages, just a '-' and then the other English and Malagasy options which only show the constraint messages correctly and all other questions are blank.
Check that you have spelt "English" and "Malagasy" the same in all your column headers. I found that I had labelled one as "english" by mistake and it then sees it as a 3rd language, and results in some of the behaviour you are seeing.
Regards,
Andrew
On Wednesday, 17 June 2015 19:03:02 UTC+2, Victori wrote:
> Hi,
> My question is about multiple language contraint messages when writing a form in excel. I have used the following in the relevant columns:
> constraint_message::English constraint_message::Malagasy
> Anyone have any ideas?
