Dear ODK Developers,
I am wondering how to develop this type of question in ODK. Please see the
picture in my attachment.
Regards
Regards
Bunhann,
You can add hints to every prompt.
http://opendatakit.org/help/form-design/binding/
picture in my attachment.Regards
"ODK Developers" group.
Dear Yaw,
Thanks for your response, but i don't mean to add hint. Sorry to make you
confuse, i want to add text box in the multiselect question. I mean that if
they response the first check box, they will have to response some
information more that need to be add but if they don't it doesn't show up.
Regards,
Bunhann,
Your best option is to have a text box that is relevant based on the
checkbox. You can't have both items on the same screen though.
If that won't do, you'll have to to write a custom widget.
On Wed, May 7, 2014 at 6:38 PM, Bunhann Thou bunhann@gmail.com wrote:
Dear Yaw,
information more that need to be add but if they don't it doesn't show up.Regards,
On Wednesday, May 7, 2014 9:23:32 PM UTC+7, Yaw Anokwa wrote:
Bunhann,
http://opendatakit.org/help/form-design/binding/Yaw
setup, professional support, and software development for ODK.On Tue, May 6, 2014 at 10:10 PM, Bunhann Thou bun...@gmail.com wrote:
the
Groups
an
Dear Yaw,
Thanks for your response. Could you guide me a little bit about this custom
widget? How do i should start?
Regards,
Bunhann,
Look at the existing widgets in ODK Collect and go from there. I
should warn that adding this kind of widget is non-trivial.
On Thu, May 8, 2014 at 8:01 AM, Bunhann Thou bunhann@gmail.com wrote:
Dear Yaw,
widget? How do i should start?Regards,
On Thursday, May 8, 2014 9:42:15 PM UTC+7, Yaw Anokwa wrote:
Bunhann,
checkbox. You can't have both items on the same screen though.If that won't do, you'll have to to write a custom widget.
setup, professional support, and software development for ODK.On Wed, May 7, 2014 at 6:38 PM, Bunhann Thou bun...@gmail.com wrote:
Dear Yaw,
you
if
up.Regards,
Bunhann,
see
the
Groups
send
an
Groups
an
Dear Yaw,
Thanks for your response. I'll start to at the existing widget.
Respect,
If you are heavily customizing ODK Collect, you might want to look way back
at ODK Collect 1.1.6, which had this capability in a field-list screen, in
addition to supporting field-list groups with relevance interdependencies
like you asked in another question.
However, that codebase is radically different from 1.1.7 and onward, so you
would be on your own if you went down that path.
Dear Yaw,
Respect,
On Thursday, May 8, 2014 10:05:27 PM UTC+7, Yaw Anokwa wrote:
Bunhann,
should warn that adding this kind of widget is non-trivial.Yaw
setup, professional support, and software development for ODK.On Thu, May 8, 2014 at 8:01 AM, Bunhann Thou bun...@gmail.com wrote:
Dear Yaw,
custom
Bunhann,
Dear Yaw,
makeyou
thatif
showup.
Regards,
Bunhann,
Pleasesee
the
You received this message because you are subscribed to theGroups
send
an
Groups
sendan
Groups
an
