Dear sir;;
I need help regarding the installation of ODK on Windows 7 ;;
RegardsMehmood
Dear sir;;
RegardsMehmood
Hi Mehmood,
If you'd like help, you'll need to provide very specific descriptions
of the problems you have having.
Software and hardware versions
Aggregate v1.x.x, Windows vx.x.x, GoogleAppEngine vs Tomcat?
Problem description
Steps to reproduce the problem
Expected behavior
Other information
Things you tried, stack traces, related issues, suggestions on how to fix it?
Alternatively, what step on https://opendatakit.org/use/aggregate/ are
you stuck on?
