Hi
I had design a audio form for ODK, and I want to freeze the screen till my
audio complete play.
I had attached the sample form and audio, Plz help….
With Regards
Vikash
Hi
With Regards
Vikash
This would require a software modification.
Hi
audio complete play.I had attached the sample form and audio, Plz help….
With Regards
Vikash
I guess you could put in a question:
"Please enter the code provided in the audio clip." and make it required,
then have the code stated at the end of the audio clip. That way they
don't get the code to move on until they've listened to all the audio.
Not perfect but might be a workaround depending on your requirements.
Jason
