I have 4 nested repeated groups as follows:
group4 in group3 in group2 in group1(pls, see the form in attach).
The problem is that, for two successive of them, if the first one is not filled, the second one does
not appear to be filled; case that we can face on the field.
In advance, thank for helping to solve this problem.
Regards,
NestedRepeatedGroups.xlsx (9.4 KB)
Hi Amal,
Try moving the end_repeat after the nested repeat modules (keep the section wrapped in the overall repeat). Example below.
Hi, @LIoyd_Banwart.
Thanks to you, so much!
it works well.
Thanks, again.
