New entities feature
Thanks for sharing part of the form definition!
This is something you are setting in the parameters column, right? If so, this means that the value saved to the farmer form field is the value of the farmer_name Entity property. In that case, your expression would be instance('buzaaya-farmer-members')/root/item[farmer_name=${farmer}]/submissionUUID.
My recommendation would be to not set an explicit value. That means the farmer field will hold the system id of the selected Entity and all your lookup expressions will use name=${farmer}. You can also look up the farmer_name value by doing something like instance('buzaaya-farmer-members')/root/item[name=${farmer}]/farmer_name
I have filed an issue to add to documentation around setting a custom value: https://github.com/getodk/docs/issues/1721
Thanks for all your suggestions. I learnt a lot and have implemnented a satisfactory working system.
Thanks to the form and its community.
Prabhakar
Is there any progress on creating an entity list from a CSV file?
"Regarding uploading CSV file to EntityList, that feature is in the pipeline. "
It will be useful to have this. I have a list of entities already listed with a geographical location and would like to use these as entities for a longitudinal study.
Prabhakar
It shipped a few days ago.
Nice. I will upgrade my Central and checkthis feature out. Congratulations to the team.
I have a question:
Can we have locatin (lat/long) as a variable? In what format should that be? Can I search nearby and locate the longitudinal study entity of interest?
Prabhakar
Prabhakar
Good morning @prabha ,
Yes you can give a geometry property to your entities.
You have to use "geometry" as column name and store the locations in the ODK format : https://docs.getodk.org/form-question-types/#location-widgets
