Hi all.
I have another problem with my forms. I have very large forms with several skips. When I was testing while designing the form, everything did work properly. But after entering hundreds of fields my odk collect can no longer display automatically the following fields. An example:
begin group --- > field-list
select_one yn -> Q1-> Have you done a HIV test?
select_one res -> Q2-> If yes, what was the result?
end group
Normally Q2 is hidden until you check "yes" to Q1. In my case, it doesn't appear. I'm obliged to move to another screen and to roll back so that it could load the following question.
You can't put prompts that depend on each other in the same field-list
(e.g., then can't be on the same screen).
On Tue, Sep 16, 2014 at 7:14 AM, Serge Somda manituo@gmail.com wrote:
Hi all.
end group
This is simply how field-list groups work: questions will not appear and
disappear dynamically within a single screen. Relevance works best when
questions are on separate screens. Sorry!
Chris
P.S. Check out www.enketo.org. Their web-based client may behave more as
you're expecting...
On Tue, Sep 16, 2014 at 10:14 AM, Serge Somda wrote:
Hi all.
end group
Too bad for me.
I'll look for another solution.
Thank you.
Serge
2014-09-16 16:18 GMT+02:00 Christopher Robert :
Chris
you're expecting...
On Tue, Sep 16, 2014 at 10:14 AM, Serge Somda manituo@gmail.com wrote:
Hi all.
end group
