Hi All,
I am using a double repeat to collect information on the number of counts during a survey and then recording the types of species and number of each, for each count.
I am trying to limit the duplicate selection of the species within each count, but not between counts. I seem to have got it somewhat right but not totally.
The no duplicate works fine within each count, and allows selection of the same species on the second count if I select the species in the same order, however, if I select the last species from the first count as the first species in the second count it recognizes it as a duplicate selection even though it is in a second repeat count.
For example
Count1
Species
Yellow
Orange
Blue
Count2
Species
Yellow
Orange
Blue
this works fine, however the following does not work:
Count1
Species
Yellow
Orange
Blue
Count2
Species
Blue
Orange
Yellow
the basic structure is (file attached)'
RepeatCount
RepeatSpecies
Species_ID
Species_Number
End RepeatSpecies
End RepeatCount
The code i am using in the constraint field of Species_ID is
not(selected(join(' ',/Repeat_NoDuplicates/RepeatPass/RepeatSpecies[./GRepeatSpecies/Species_ID and position(.) !=position(current()/../..)]/GRepeatSpecies/Species_ID),.))
I would appreciate any advice on finding the probem.
Regards,
Repeat_NoDuplicates.xlsx (17.0 KB)
