I have a quick and embarrassing question. When I try to create my own
instance of aggregate I get nowhere,
I unzip the 0.9.4 odk package
Create the application called #####.appspot.com
Then I run the uploadaggregatetoappengine.cmd
I'm on windows, It shows the black window for just a split second and
then nothing... I know I'm missing something simple.
Any help for this n00b would be appreciated. Not sure what I'm
missing. I tried it on two different computers following the tutorial
steps, and I get the same result both times.
First guess ... Do you have Java installed on your computer? The
installer uses a java program to upload.
On Tue, Feb 8, 2011 at 8:00 AM, Travis wrote:
> Hi Folks,
> Travis
I'll sheepishly crawl back to my n00b cave to collect data.
Travis
> > Hi Folks,
> > Travis
