I have a repeating form, a drop down field to display family member name.
Can I prevent data collector select a family member more than 1 time?
Is there any solution?
Thanks a lot for any suggestion.
Hi and welcome to the forum! If you have a moment, introduce yourself here!
What kind of Select are you using, SelectOne or SelectMultiple?
Could you share your form here, or a very basic example form where you can show how users could (but should not) select an option multiple times?
