We've connected ODK-Voice to OpenMRS where once a phone encounter is
finished the xform is passed into OpenMRS. However, in the last few weeks
I've begun getting an error when ODK-Voice tries to pass the xForm in. The
error is
ERROR - XformsQueueProcessor.processXForm(210) |2011-04-28 15:11:13,123|
Invalid dateTime value. Too short ValidationException: Invalid dateTime
value. Too short
When I look at the xform being pushed, I see that the encounter_datetime
only has a date and no time
<encounter.encounter_datetime openmrs_table="encounter"
openmrs_attribute="encounter_datetime">2011-04-26</encounter.encounter_datetime>
and I've modified the xforms module in OpenMRS to receive date and time, not
just date. So I think that's the cause. I've tried using both now() and
current-dateTime in the XForm being used in ODK-Voice in this format
openmrs_attribute="encounter_datetime">'current-dateTime()'</encounter.encounter_datetime>
but I always get just a date back. The XForms module from what I can tell
needs an input of yyyy-MM-dd'T'HH:mm:ssZ
Joaquin
___________________________________________________________________
Gerente de Desarrollo, eHealth Systems
Research Fellow, Escuela de Medicina de Harvard
Moderador, GHDOnline.org
joaquín,
not sure if this will help, but in your bind for the
encounter_datetime, try using "dateTime" instead of "date".
yaw
> error is
> value. Too short
> Thanks,
> Joaquin
Thanks Yaw, unfortunately that didn't change anything, it still only outputs
a date without time. I also tried changing the code on the servlet that
we're using to send the data in order for it to write a date and time, but
ODK-Voice overwrites it. I'm going to email Adam now, but I'd appreaciate
any other suggestions.
Joaquin
On Fri, Apr 29, 2011 at 11:44 AM, Yaw Anokwa wrote:
joaquín,
yaw
weeks
The
error is
value. Too short
not
Joaquin
