hello community members
i am using web based VPS hosting for ODK Aggregate every things in configuration looks to be fine
i am using JVM inside the VPS and using apatche tomcat 6 and jdk 1.6
but i'm getting error while redirecting to forms page described in screenshot below
anyone can help me please
thanks in advance
Dear Khalil,
As an initial step, I would recommend you use the latest versions of Tomcat, java, and Aggregate. The versions you mentioned are not the latest.
There are also detailed install instructions here:
https://docs.opendatakit.org/aggregate-tomcat/
That may be helpful.
Caroline
thank you
i think problem is not with version because the previous version also works i have tried with Local apatche tomcat when it comes to web
some problems occurs
regards
