Carl you are exactly right and now that I think about it the behavior
(sorta) makes sense. Thanks about the tip of the 'back' button that does
seem to work (as a work around) but because the keyboard is covering up the
inputs under it it is not obvious that there are more inputs.
I know Collect thinks its doing us a favor by popping up the keyboard if it
sees only text inputs on a page but it would be better if it didn't. And
practically it doesn't save any time because it would pop it up when you
select a text input box anyway. And if it wasn't there you would see all the
fields that it hides when it pops up. Is it possible to have a 'hidden'
input box, for example a select input, that isn't visible (or take space)
then the keyboard would not automatically pop up. (At least I've found where
I mix input flavors on a page it doesn't pop up.)
-steve-
On Wed, Jun 8, 2011 at 12:52 PM, Carl Hartung wrote:
Hey Steve,
My guess is you've got 3 or 4 text inputs? The problem seems to be that
you don't have enough inputs (text or other) to over-fill a screen so
Android doesn't think it should scroll. Then, when one of the top inputs is
selected the keyboard covers the bottom. If you have more inputs than fit
on a screen, the scrolling still works above the keyboard.
However, if you hit the 'back' button when the keyboard is up, the keyboard
should get dismissed and reveal your hidden text inputs. Then you should be
able to select the input and it will get moved above the soft-keyboard when
it pops up. I tested both of the above with Swype on my phone and it worked
as expected.
I think I remember reading something about manually handling screen size
changes (like when the keyboard pops ups), so I'll look into it and see if I
can force enable the scrolling.
-Carl
On Wed, Jun 8, 2011 at 11:13 AM, Steve Roberts steve@roberts.org wrote:
I had no problem with 1.1.7 installing and the old forms worked just
fine. However I am having problems with multiple text inputs on one page.
If I have more than 2 then I can't scroll down to the ones covered by the
(swype) on-screen keyboard. I can't dismiss the keyboard and scroll
either. I do notice on other pages that have a mix of input types it
doesn't seem to be a problem.
-steve-
On Wed, Jun 8, 2011 at 11:03 AM, Carl Hartung carlhartung@gmail.comwrote:
Hey Kirby,
For Aggregate, you can install up to 10 instances on appengine or install
it on your local machine. So yes, you can create another instance and
operate it in parallel.
For Collect, it will override your existing version. It won't delete
your data, though. Your forms will be re-detected automatically. Your
saved data will still be on the sdcard, but the new version won't be able to
read it (from this version on, upgrading shouldn't cause this problem,
though).
I'll let Waylon or Mitch comment about the status of programatic access
to aggregate data and the tool to migrate data from a .9x instance to a 1.0
-Carl
On Wed, Jun 8, 2011 at 8:22 AM, KirbyJames kirby.james@gmail.comwrote:
Carl,
Thanks for the advice on 'new/updated' features.
Another coupled of questions ...
I've got an exsting Collect/Aggregate instance. Can I install the
betas in parallel with my existing instances - or will they over-write
my existing versions and data?
I'd naturally like to try out the betas without compromising existing
data (i.e. data I've collected already).
I believe there was planned to be some migration tool - is this
available?
I understand there was planned to be a new method of accessing data
held under Aggregate programatically - are details of this interface
available?
Many Thanks
Kirby
Hey Steve,
The behavior of Collect is to pop up a soft keyboard if a textbox is the
first or only input on a page. For all other widget types (as the first or
only) the keyboard is hidden. This was a highly requested feature
originally when we only supported a single question per screen to minimize
'clicks'.
I just checked in a fix that makes the field scrollable when the
soft-keyboard pops up automatically. Now it's the exact same behavior as a
screen with no text-inputs and too many elements to fit on the screen. That
is, it shows the scroll bar to indicate there are more fields.
-Carl
-steve-
On Wed, Jun 8, 2011 at 12:52 PM, Carl Hartung carlhartung@gmail.comwrote:
Hey Steve,
keyboard should get dismissed and reveal your hidden text inputs. Then you
should be able to select the input and it will get moved above the
soft-keyboard when it pops up. I tested both of the above with Swype on my
phone and it worked as expected.
-Carl
-steve-
Hey Kirby,
install it on your local machine. So yes, you can create another instance
and operate it in parallel.
though).
-Carl
Carl,
available?
available?
Many Thanks
Kirby
Carl,
Thanks for the quick response and fix. Does that mean I just re-download
the beta and that fixes it?
Speaking of minimizing clicks... Is there a way that once a form is "Save
Form and Exit" that it can loop back to the start of the next instance of
that form. Otherwise you got to 'click' several times just to get to the
start of the form entry.
Thanks again.
-steve-
On Fri, Jun 10, 2011 at 11:49 AM, Carl Hartung wrote:
Hey Steve,
'clicks'.
-Carl
it sees only text inputs on a page but it would be better if it didn't. And
-steve-
Hey Steve,
-Carl
-steve-
Hey Kirby,
though).
-Carl
Carl,
available?
available?
Many Thanks
Kirby
steve,
the fix will be in the next beta release, so you'll have to wait for
that. there is no way to loop back to the start of the next instance.
you might look into repeats (or custom code) if you want that kind of
functionality.
yaw
On 06/10/2011, Steve Roberts wrote:
> Carl,
> Thanks again.
> -steve-
>> Hey Steve,
>> or
>> 'clicks'.
>> a
>> That
>> -Carl
>>> the
>>> And
>>> the
>>> where
>>> -steve-
>>>> Hey Steve,
>>>> inputs is
>>>> fit
>>>> you
>>>> my
>>>> if I
>>>> -Carl
>>>>> page.
>>>>> the
>>>>> -steve-
>>>>> On Wed, Jun 8, 2011 at 11:03 AM, Carl Hartung wrote:
>>>>>> Hey Kirby,
>>>>>> instance
>>>>>> Your
>>>>>> able to
>>>>>> though).
>>>>>> access
>>>>>> a 1.0
>>>>>> -Carl
>>>>>> On Wed, Jun 8, 2011 at 8:22 AM, KirbyJames wrote:
>>>>>>> Carl,
>>>>>>> over-write
>>>>>>> available?
>>>>>>> available?
>>>>>>> Many Thanks
>>>>>>> Kirby
>>>>>>> Post: opendatakit@googlegroups.com
>>>>>>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com
>>>>>>> Options: http://groups.google.com/group/opendatakit?hl=en
Thanks Yaw,
I wasn't aware of 'repeats' and showing my ignorance when I (just now) found
the documentation (http://code.dimagi.com/JavaRosa/wiki/xform) and it is
pretty much Greek to me.
It says:
"We also support the tag, which allows repeating a question or set
of questions an arbitrary number of times. The nodeset attribute of the
specifies the instance node to be parameterized -- that is, it is
this exact node (and all its children) which is duplicated each time a new
repetition is created. Our implementation of is pretty standard,
but it diverges in several ways.
In pure xforms, 'create new repetition' and 'delete repetition' actions are
initiated manually by the user, who does so using special controls
created explicitly for this purpose. JavaRosa provides these actions
automatically as part of the form entry UI. For example, the user will be
prompted when necessary if they want to create a new repetition, and when
they are inside a , the 'delete' option is available under a menu.
These s are unnecessary, and will be ignored if present."
I couldn't make heads or tails out of the examples. Does this mean that I
could put the whole form in a 'repeat' and then somehow at the end of the
form put a button or something asking if I wanted to repeat the questions
then go back to the start if answered yes?
Thanks.
-steve-
On Sat, Jun 11, 2011 at 2:43 AM, Yaw Anokwa wrote:
steve,
functionality.
yaw
On 06/10/2011, Steve Roberts steve@roberts.org wrote:
Carl,
Thanks again.
-steve-
On Fri, Jun 10, 2011 at 11:49 AM, Carl Hartung <carlhartung@gmail.com wrote:
Hey Steve,
or
minimize
'clicks'.
as
a
That
-Carl
does
the
if
And
you
all
the
'hidden'
space)
where
-steve-
Hey Steve,
that
inputs is
fit
Then
you
on
my
size
see
if I
-Carl
page.
the
-steve-
Hey Kirby,
instance
delete
Your
able to
problem,
though).
access
to
a 1.0
-Carl
Carl,
over-write
existing
available?
interface
available?
Many Thanks
Kirby
steve,
yes. you can put questions inside a repeat and at the end of all the questions, it will ask you if you want to create another repeat. say yes, and it will.
take a look at the household forms (http://code.google.com/p/opendatakit/source/browse/Household+Survey.xml?repo=forms#201) and you'll see a hopefully clear example of how repeats are used.
you can put default data in your repeats and also refer to data within the repeat. so if you enter a child's name in the repeat from the form above, you can use the text of that name when asking about that child's favorite color.
note that there is a jr:template tag that goes into the instance. if you want the form to ask you at the beginning of the repeat about creating a new repeat, keep the template in. if you want to bypass that dialog, remove it. the template thing is confusing, but that's what we have to work with.
anyway. best way to see this in action is to try it out.
yaw
On Jun 11, 2011, at 6:16 PM, Steve Roberts wrote:
Thanks Yaw,
I wasn't aware of 'repeats' and showing my ignorance when I (just now) found the documentation (http://code.dimagi.com/JavaRosa/wiki/xform) and it is pretty much Greek to me.
It says:
"We also support the tag, which allows repeating a question or set of questions an arbitrary number of times. The nodeset attribute of the specifies the instance node to be parameterized -- that is, it is this exact node (and all its children) which is duplicated each time a new repetition is created. Our implementation of is pretty standard, but it diverges in several ways.
In pure xforms, 'create new repetition' and 'delete repetition' actions are initiated manually by the user, who does so using special controls created explicitly for this purpose. JavaRosa provides these actions automatically as part of the form entry UI. For example, the user will be prompted when necessary if they want to create a new repetition, and when they are inside a , the 'delete' option is available under a menu. These s are unnecessary, and will be ignored if present."
I couldn't make heads or tails out of the examples. Does this mean that I could put the whole form in a 'repeat' and then somehow at the end of the form put a button or something asking if I wanted to repeat the questions then go back to the start if answered yes?
Thanks.
-steve-
On Sat, Jun 11, 2011 at 2:43 AM, Yaw Anokwa yanokwa@gmail.com wrote:
steve,
functionality.
yaw
Carl,
Thanks again.
-steve-
On Fri, Jun 10, 2011 at 11:49 AM, Carl Hartung carlhartung@gmail.comwrote:
Hey Steve,
or
'clicks'.
a
That
-Carl
the
And
the
where
-steve-
Hey Steve,
inputs is
fit
you
my
if I
-Carl
page.
the
-steve-
Hey Kirby,
instance
Your
able to
though).
access
a 1.0
-Carl
Carl,
over-write
available?
available?
Many Thanks
Kirby
Yaw,
Thanks. That is helpful. Later today (After the UW graduation
I'll
play with it.
As an editorial it does seem like it might be useful to have an option to
submit the current form and start the next. (maybe a menu option) I suppose
if walking between homes/huts between forms its not a big deal to start
fresh for each entry but if you are sitting annotating fish going through a
fish ladder you could be 'clicking' more clicks getting to the form than
entering the data. (Big Fish, Small Fish)
(But as they say "beggars can't be choosers"
Thanks guys for all you do.
-steve-
On Sat, Jun 11, 2011 at 8:30 AM, Yaw Anokwa wrote:
steve,
and it will.
color.
yaw
Thanks Yaw,
It says:
Thanks.
-steve-
steve,
functionality.
yaw
Carl,
re-download
"Save
of
the
Thanks again.
-steve-
Hey Steve,
the
first
or
minimize
'clicks'.
as
a
That
-Carl
does
up
the
if
didn't.
And
you
all
the
'hidden'
space)
found
where
-steve-
Hey Steve,
that
so
inputs is
than
fit
Then
you
Swype on
my
size
see
if I
-Carl
just
one
page.
by
the
scroll
it
-steve-
Hey Kirby,
instance
delete
Your
be
able to
problem,
though).
access
to
a 1.0
-Carl
Carl,
over-write
existing
available?
data
interface
available?
Many Thanks
Kirby
As another option, 1.1.7 will let you create a desktop shortcut to a
specific form. Just long press on the desktop to create a shortcut. Using
the shortcut will start you in a specific form and saving/exiting will take
you back to the desktop.
On Sat, Jun 11, 2011 at 8:50 AM, Steve Roberts wrote:
Yaw,
I'll
play with it.
-steve-
On Sat, Jun 11, 2011 at 8:30 AM, Yaw Anokwa yanokwa@gmail.com wrote:
steve,
and it will.
color.
yaw
Thanks Yaw,
It says:
Thanks.
-steve-
steve,
functionality.
yaw
Carl,
re-download
"Save
of
the
Thanks again.
-steve-
Hey Steve,
the
first
or
minimize
'clicks'.
behavior as
a
screen.
That
-Carl
behavior
does
up
the
keyboard if
didn't.
And
you
all
the
'hidden'
space)
found
where
-steve-
Hey Steve,
that
so
inputs is
than
fit
Then
you
Swype on
my
size
see
if I
-Carl
just
one
page.
by
the
scroll
it
-steve-
Hey Kirby,
instance
delete
Your
be
able to
problem,
though).
access
instance to
a 1.0
-Carl
Carl,
the
over-write
existing
available?
data
interface
available?
Many Thanks
Kirby
hmmmm.. I'm having trouble figuring out what you mean. I assume the form
you want the shortcut to needs to be open or selected or something. Can you
give me a few more details on creating the shortcut?
-steve-
-- Painfully slowly typed on my htc EVO --
On Sat, Jun 11, 2011 at 8:50 AM, Steve Roberts steve@roberts.org wrote:
Yaw,
I'll
play with it.
-steve-
steve,
and it will.
favorite color.
yaw
Thanks Yaw,
It says:
Thanks.
-steve-
steve,
functionality.
yaw
Carl,
re-download
"Save
instance of
the
Thanks again.
-steve-
On Fri, Jun 10, 2011 at 11:49 AM, Carl Hartung < carlhartung@gmail.com>wrote:
Hey Steve,
the
first
or
minimize
'clicks'.
behavior as
a
screen.
That
-Carl
behavior
does
covering up
the
keyboard if
didn't.
And
when you
see all
the
'hidden'
space)
found
where
-steve-
Hey Steve,
be that
so
inputs is
than
fit
Then
you
Swype on
my
screen size
and see
if I
-Carl
just
one
page.
covered by
the
scroll
types it
-steve-
Hey Kirby,
or
another
instance
delete
automatically.
Your
won't be
able to
problem,
though).
access
instance to
a 1.0
-Carl
Carl,
the
over-write
existing
available?
data
interface
available?
Many Thanks
Kirby
Sure thing. First, make sure that the form appears in ODK's list when you
press 'start new form'.
Then:
press the phone's home button to get to your desktop/home screen ->
press-and-hold on any blank space until a menu appears -> shortcut -> ODK
Form -> [whatever form you want]
-steve-
Yaw,
I'll
play with it.
-steve-
steve,
and it will.
favorite color.
yaw
Thanks Yaw,
It says:
Thanks.
-steve-
steve,
functionality.
yaw
Carl,
re-download
"Save
instance of
to the
Thanks again.
-steve-
Hey Steve,
is the
first
or
minimize
'clicks'.
behavior as
a
screen.
That
-Carl
behavior
that does
covering up
the
keyboard if
didn't.
And
when you
see all
the
'hidden'
space)
found
where
-steve-
Hey Steve,
be that
screen so
top
inputs is
than
fit
the
Then
you
the
Swype on
my
screen size
and see
if I
-Carl
just
one
page.
covered by
the
scroll
types it
-steve-
Hey Kirby,
or
another
instance
delete
automatically.
Your
won't be
able to
problem,
though).
programatic
access
instance to
a 1.0
-Carl
Carl,
the
over-write
existing
this
available?
data
interface
available?
Many Thanks
Kirby
Excellent!
-steve-
Then:
-steve-
On Sat, Jun 11, 2011 at 8:50 AM, Steve Roberts steve@roberts.orgwrote:
Yaw,
I'll play with it.
to submit the current form and start the next. (maybe a menu option) I
suppose if walking between homes/huts between forms its not a big deal to
start fresh for each entry but if you are sitting annotating fish going
through a fish ladder you could be 'clicking' more clicks getting to the
form than entering the data. (Big Fish, Small Fish)
-steve-
steve,
and it will.
favorite color.
yaw
Thanks Yaw,
Greek to me.
It says:
Thanks.
-steve-
steve,
functionality.
yaw
Carl,
re-download
"Save
instance of
to the
Thanks again.
-steve-
Hey Steve,
is the
first
or
minimize
'clicks'.
behavior as
a
screen.
That
-Carl
behavior
that does
covering up
the
keyboard if
didn't.
And
when you
see all
the
'hidden'
take space)
found
where
-steve-
Hey Steve,
be that
screen so
top
inputs is
inputs than
fit
the
inputs. Then
you
the
Swype on
my
screen size
and see
if I
-Carl
just
on one
page.
covered by
the
scroll
types it
-steve-
Hey Kirby,
or
another
instance
delete
automatically.
Your
won't be
able to
problem,
though).
programatic
access
instance to
a 1.0
-Carl
Carl,
the
over-write
existing
this
available?
accessing data
interface
available?
Many Thanks
Kirby
Hmmm. My Evo broke and I replaced it and am reinstalling my apps. I just
installed 1.1.7 Beta 2. It works and my forms on my sd card seemed to all be
happy. However I can't make a shortcut. I start odk, bring up the form I
want, press home and bring up the short-cut list and odk is not on it. I
have the latest android update for 2.3.3. (I don't do this often. In fact
have only done it for odk. Am I missing a step?) Thanks. -steve-
Then:
-steve-
Yaw,
I'll play with it.
-steve-
steve,
and it will.
favorite color.
yaw
Thanks Yaw,
Greek to me.
It says:
Thanks.
-steve-
steve,
functionality.
yaw
Carl,
re-download
"Save
instance of
to the
Thanks again.
-steve-
Hey Steve,
is the
first
or
minimize
'clicks'.
behavior as
a
screen.
That
-Carl
behavior
that does
covering up
the
keyboard if
didn't.
And
when you
see all
the
'hidden'
take space)
found
where
-steve-
Hey Steve,
be that
screen so
top
inputs is
inputs than
fit
the
inputs. Then
you
the
Swype on
my
screen size
and see
if I
-Carl
just
on one
page.
covered by
the
scroll
types it
-steve-
Hey Kirby,
or
another
instance
delete
automatically.
Your
won't be
able to
problem,
though).
programatic
access
instance to
a 1.0
-Carl
Carl,
the
over-write
existing
this
available?
accessing data
interface
available?
Many Thanks
Kirby
can't duplicate it on my phone, but sounds like a bug somewhere. i've filed
it at http://code.google.com/p/opendatakit/issues/detail?id=264.
>> Then:
>>> -steve-
>>>>> Yaw,
>>>>> Thanks. That is helpful. Later today (After the UW graduation ;-)
>>>>> I'll play with it.
>>>>> (But as they say "beggars can't be choosers" :-)
>>>>> -steve-
>>>>>> steve,
>>>>>> and it will.
>>>>>> favorite color.
>>>>>> yaw
>>>>>> > Thanks Yaw,
>>>>>> > It says:
>>>>>> > Thanks.
>>>>>> > -steve-
>>>>>> > steve,
>>>>>> > instance.
>>>>>> > of
>>>>>> > functionality.
>>>>>> > yaw
>>>>>> > > Carl,
>>>>>> > > re-download
>>>>>> > > is "Save
>>>>>> > > instance of
>>>>>> > > to the
>>>>>> > > Thanks again.
>>>>>> > > -steve-
>>>>>> > >> Hey Steve,
>>>>>> > >> is the
>>>>>> > >> the first
>>>>>> > >> or
>>>>>> > >> feature
>>>>>> > >> minimize
>>>>>> > >> 'clicks'.
>>>>>> > >> behavior as
>>>>>> > >> a
>>>>>> > >> screen.
>>>>>> > >> That
>>>>>> > >> -Carl
>>>>>> > >>> behavior
>>>>>> > >>> that does
>>>>>> > >>> covering up
>>>>>> > >>> the
>>>>>> > >>> keyboard if
>>>>>> > >>> didn't.
>>>>>> > >>> And
>>>>>> > >>> when you
>>>>>> > >>> see all
>>>>>> > >>> the
>>>>>> > >>> 'hidden'
>>>>>> > >>> take space)
>>>>>> > >>> found
>>>>>> > >>> where
>>>>>> > >>> -steve-
>>>>>> > >>>> Hey Steve,
>>>>>> > >>>> to be that
>>>>>> > >>>> screen so
>>>>>> > >>>> top
>>>>>> > >>>> inputs is
>>>>>> > >>>> inputs than
>>>>>> > >>>> fit
>>>>>> > >>>> the
>>>>>> > >>>> inputs. Then
>>>>>> > >>>> you
>>>>>> > >>>> the
>>>>>> > >>>> Swype on
>>>>>> > >>>> my
>>>>>> > >>>> screen size
>>>>>> > >>>> and see
>>>>>> > >>>> if I
>>>>>> > >>>> -Carl
>>>>>> > >>>>> worked just
>>>>>> > >>>>> on one
>>>>>> > >>>>> page.
>>>>>> > >>>>> covered by
>>>>>> > >>>>> the
>>>>>> > >>>>> scroll
>>>>>> > >>>>> types it
>>>>>> > >>>>> -steve-
>>>>>> > >>>>>> Hey Kirby,
>>>>>> > >>>>>> appengine or
>>>>>> > >>>>>> another
>>>>>> > >>>>>> instance
>>>>>> > >>>>>> won't delete
>>>>>> > >>>>>> automatically.
>>>>>> > >>>>>> Your
>>>>>> > >>>>>> won't be
>>>>>> > >>>>>> able to
>>>>>> > >>>>>> problem,
>>>>>> > >>>>>> though).
>>>>>> > >>>>>> programatic
>>>>>> > >>>>>> access
>>>>>> > >>>>>> instance to
>>>>>> > >>>>>> a 1.0
>>>>>> > >>>>>> -Carl
>>>>>> > >>>>>>> Carl,
>>>>>> > >>>>>>> install the
>>>>>> > >>>>>>> over-write
>>>>>> > >>>>>>> existing
>>>>>> > >>>>>>> this
>>>>>> > >>>>>>> available?
>>>>>> > >>>>>>> accessing data
>>>>>> > >>>>>>> interface
>>>>>> > >>>>>>> available?
>>>>>> > >>>>>>> Many Thanks
>>>>>> > >>>>>>> Kirby
I didn't have any problem before when Carl showed me how it was done. Hope I
can figure it out as saves a lot of clicks for a single form
-steve-
filed
just
be
I
fact
you
Then:
ODK
form
Can you
-steve-
Using
take
Yaw,
I'll play with it.
option
I
deal to
going
the
-steve-
steve,
yes,
and it will.
within
form
child's
favorite color.
creating a
remove
with.
yaw
Thanks Yaw,
It says:
question
attribute of
that is, it
time a
pretty
special
provides
example, the
option is
be
mean
the end of
the
Thanks.
-steve-
steve,
for
instance.
of
functionality.
yaw
Carl,
re-download
is "Save
instance of
get
to the
Thanks again.
-steve-
Hey Steve,
textbox
is the
the first
or
feature
to
minimize
'clicks'.
the
behavior as
a
screen.
That
-Carl
behavior
that does
covering up
the
keyboard if
it
didn't.
And
up
when you
would
see all
the
a
'hidden'
take space)
I've
found
where
-steve-
Hey Steve,
to be that
screen so
the
top
inputs is
inputs than
fit
up,
the
inputs. Then
you
above
the
with
Swype on
my
screen size
it
and see
if I
-Carl
worked just
inputs
on one
page.
covered by
the
and
scroll
types it
-steve-
Hey Kirby,
appengine or
another
instance
won't delete
automatically.
Your
won't be
able to
this
problem,
though).
programatic
access
instance to
a 1.0
-Carl
Carl,
install the
they
over-write
compromising
>>>>>>> > >> On Wed, Jun 8, 2011 at 1:11 PM, Steve Roberts < steve@roberts.org> wrote:
>>>>>>> > >>>>>>> existing
>>>>>>> > >>>>>>> this
>>>>>>> > >>>>>>> available?
>>>>>>> > >>>>>>> accessing data
>>>>>>> > >>>>>>> interface
>>>>>>> > >>>>>>> available?
>>>>>>> > >>>>>>> Many Thanks
>>>>>>> > >>>>>>> Kirby
