Hi
I am busy working on a project with a large csv file that I would like to filter by asking for a prompt that asks for the first letter of the csv entry and then filter the csv on the next screen acording to that.
I tried these two filters in the choice_filter column so far but they have not worked:
choice_item.landing_site.startsWith(data('landing_site_first'))
choice_item.landing_site.substring(1) === (data('landing_site_first').substring(1))
I might be missing something fairly obvious, but have not found something to make this work in the documentation so far.
Thanks for your time.
Werner
See the "select one with search" prompt
https://opendatakit.org/help/form-design/examples/#select_prompts
This was added in the most recent ODK Collect release.
On Fri, Jul 8, 2016 at 1:38 AM, wrote:
Hi
not worked:
Werner
To do this with the 2.0 tools, using the choice_filter is the right
approach. I've attached an example of how to do this. The choice_filter
that I use is below.
choice_item.key.substring(0,1) === data('first_letter')
Here I am filtering the rows in the CSV file based on the key column of the
birds.csv file starting with the same letter entered in for the
first_letter text prompt.
Clarice
selects.zip (1.42 MB)
On Fri, Jul 8, 2016 at 1:38 AM, wvdm1217@gmail.com wrote:
Hi
have not worked:
Werner
