See http://code.google.com/p/opendatakit/wiki/SurveyReleaseNotes
for information about how to construct an XML form from the json and other
information.
On Sun, Feb 10, 2013 at 7:49 PM, Audrey Henkels wrote:Hi Nathan,
I see the link to the 2.0 converter, which converts .xls into .json.
However, it seems the form needs to be in .xml in order to upload even
into the V3 aggregate appspot.The sample 2.0 converter form only has 3 sheets. Is it not possible
yet to upload sample ODK survey forms to the appspot - can we only
test out the example forms provided?Thanks so much for clarifying.
AudreyOn Thu, Feb 7, 2013 at 7:44 PM, Nathan Breit nabreit@gmail.com wrote:
Hi Audrey,
There are upload and conversion scripts you'll need to download.
You'll find some instructions on how to use them at the bottom of this
page:
Regards,
-NathanOn Thu, Feb 7, 2013 at 12:41 AM, Audrey Henkels < audrey.henkels@gmail.com> wrote:
Thanks for posting "XLSForm2Docs." I tried to upload the "selects"
example
form (which has four spreadsheets, including queries), into a Aggregate
v1.3
Appspot I have set up. I used the updated forms converter
(http://ec2-50-16-84-43.compute-1.amazonaws.com/xlsform/2/) which
converts
from .xls to .json. How do I then convert the form to .xml to be able to
upload into the appspot? Is there a script I need to download? If you
could
point me in the right direction I would very much appreciate it.Thanks so much for your help.
Audrey
http://www.OpenDataKit.org http://www.opendatakit.org/
