Is there a link to or any document(s) specific to ODK 2.0 on setting up the development environment for building the ODK 2.0 tool suite components?
I have seen some docs but not sure if they are the most up to date.
Thanks.
regards,
tom
Thanks.
regards,
tom
Hi Tom,
We have steps for setting up the 2.0 tools here on our wiki:
Each individual project's README.md file also includes instructions for
that its own particular setup. Note that the latest code is on the
'development' branch. For example, here's Tables' readme:
Be aware that our build scripts are under active development and are not
necessarily stable on the development branch.
Regards,
Jeff
the development environment for building the ODK 2.0 tool suite components?I have seen some docs but not sure if they are the most up to date.
Thanks.
regards,
tom--
"ODK Developers" group.
As Jeff points out, there are lots of changes happening on the development
branch that have not been reflected in our documentation on
https://opendatakit.org. If you want to take advantage of this
documentation, you will have to use the jan2015 branches of the tools which
correspond to rev 126. Our next release of the tools will have major
changes and our documentation will be updated accordingly at that time.
Clarice
Hi Tom,
https://github.com/opendatakit/opendatakit/wiki/DevEnv-SetupEach individual project's README.md file also includes instructions for
https://github.com/opendatakit/tables/blob/development/README.mdBe aware that our build scripts are under active development and are not
necessarily stable on the development branch.Regards,
Thanks.
regards,
tom--
