Hi
When pushing a parent form with multiple subforms to a device is it possible to hide the subforms from the ODK Survey menu.
An example I can use is the Farm Survey that has two subforms(Fields and Crops).
When you add them to the tablet you can see all forms. I guess you must put a specific setting in for the subforms. If anyone can help me with what setting that is that would be great.
Thank you for your time.
Werner
