Hi, I am Oscar and am trying to work with Aggregate, using Apache Tomcat 9.
Anytime I try to connect localhost:8080/ODKAggregate, I get the message "You
do not have permission for this action. Error: Invalid request"
Is there a way I can work around It. I can't downgrade to tomcat 6 or 7
because I am using other Apps that works perfectly with the tomcat 9.
Thank You
May be you have another applications running on the 8080t. So according to
me, you have to change the 8080 to something like 8089 (during the
standalone installation) and try again.
> 9. Anytime I try to connect localhost:8080/ODKAggregate, I get the message "You
> Thank You
Agyei,
It's probably not a port conflict. Look at the logs. What do they say?
"You do not have permission for this action. Error: Invalid request"
Thank You
Agyei,
Depends on your operating system, but there is generally a logs folder
in the Tomcat folder you installed. Search the web for "Tomcat logs
your_operating_system".
On Fri, Mar 11, 2016 at 12:07 PM, Agyei oscar scrwho@gmail.com wrote:
Hello Yaw,
How do I get to the Log
On Mon, Mar 7, 2016 at 11:06 AM, Yaw Anokwa yanokwa@nafundi.com wrote:
Agyei,
to
Tomcat
message
Thank You
Groups
an
https://groups.google.com/d/topic/opendatakit/7LNF0MlOM48/unsubscribe.
Hello Yaw,
I have seen the log file. Find attached.
Oscar
commons-daemon.2016-03-11.log (3.46 KB)
tomcat9-stdout.2016-03-11.log (142 KB)
manager.2016-03-11.log (19.1 KB)
On 11/03/2016 11:32 AM, Yaw Anokwa wrote:
> Agyei,
> Yaw
Oscar,
Looks like you are running other services (openhds) on this machine?
It's going to be hard to tease out the issue if you have other systems
running in parallel.
My recommendation is to temporarily turn off the other services and
reboot so you get clean logs, or find another machine that you can
install Tomcat 9.
Also, note that core team and the community in general doesn't use
Tomcat 9, so there is only so much support that you'll be able to get
on this list...
On Fri, Mar 11, 2016 at 4:23 PM, Oscar scrwho@gmail.com wrote:
Hello Yaw,
Oscar
Agyei,
--- You received this message because you are subscribed to the Google
Hello Yaw,
I tried it on a different machine, installing the Aggregate without the
openhds and I am having the same error.
Attached is my log. I am going to uninstall tomcat 9 and try 6 or 7 to
check if I would have the same issue.
Oscar
catalina.2016-03-14.log (23.8 KB)
On Mon, Mar 14, 2016 at 5:47 AM, Yaw Anokwa wrote:
Oscar,
install Tomcat 9.
on this list...
Hello Yaw,
Oscar
Agyei,
Note that there are special configuration steps required for Tomcat 7 (
https://opendatakit.org/use/aggregate/tomcat-install/ ). i.e.,
When you do find the necessary configuration changes for Tomcat 9 (or 8),
please share with this list so that the documentation can be updated with
that information.
On Mon, Mar 14, 2016 at 11:19 AM, Agyei oscar wrote:
Hello Yaw,
Oscar
On Mon, Mar 14, 2016 at 5:47 AM, Yaw Anokwa yanokwa@nafundi.com wrote:
Oscar,
install Tomcat 9.
on this list...
Hello Yaw,
Oscar
Agyei,
an
Thanks Mitch.
I will be happy to share any fix I find.
that information.
On Mon, Mar 14, 2016 at 11:19 AM, Agyei oscar scrwho@gmail.com wrote:
Hello Yaw,
Oscar
Oscar,
install Tomcat 9.
on this list...
Hello Yaw,
Oscar
Agyei,
an
