Thank you for your assistance.
It may be that your security software has removed execute privileges on
the directories and files in the TMP/TEMP path? Or that it has restricted
the permissions of the installer because it came from the internet???
The installer creates a directory named ODK-xxxxxxxx-xxxx-xxxx-xxxx-**
xx**xxxxxxxxxx (x's are digits and a-f characters) in this TEMP / TMP
directory (your settings for these are fine -- I have the same settings).
The ODK-... directory and everything underneath should have full
read-execute permissions.
When you launch the installer, before you advance past the Welcome
screen, you should be able to use your Windows Explorer file browser to
browse to view that file, e.g.,
C:\Users\yourUserName\AppData****Local\Temp
These directories may be hidden, so you might have to type this in.
Within that TEMP directory (in which ODK-... is created), the installer
will also create a 'bitrock_installer_nnnn.log' file. What does yours
contain?
Here is an example of mine, after advancing to the licensing screen and
cancelling out.
-------bitrock_installer_4894.log-----------------------------
Log started 10/17/2012 at 08:50:55
Preferred installation mode : win32
Trying to init installer in mode win32
Mode win32 successfully initialized
Setting variable default_hostname from C:/Program
Files/Java/jdk1.6.0_35/jre/bin/java.exe QualifiedHostname
Script exit code: 0
Script output:
128.208.4.20
Script stderr:
Setting variable gen_security_server_siteKey from C:/Program
Files/Java/jdk1.6.0_35/jre/bin/java.exe GenerateUUID
Script exit code: 0
Script output:
7ec3ff2c-0431-418c-8c06-6a9f5eeac454
Script stderr:
Setting variable gen_security_server_userServiceKey from
C:/Program Files/Java/jdk1.6.0_35/jre/bin/java.exe GenerateUUID
Script exit code: 0
Script output:
cd5cf3ad-1acc-4e0e-9528-85d1819c1c30
Script stderr:
Deleting registry keys
On Wed, Oct 17, 2012 at 2:15 AM, Celestine mkama cel...@gmail.comwrote:
Hi Everyone
I am having a problem in installing ODK aggregate(ODK Aggregate
v1.2.0 windows-installer) on my Computer. I get the below error everytime i
try to run the package
Error
Error running C:/Program Files/Java/jre7/bin/java.exe
QualifiedHostname : Error: Could not find or load main class
QualifiedHostname
OK
I have the following setting in environment variable (I am using
Windows 7 Professional)
User Variables
TEMP
%USERPROFILE%\AppData\Local**Te**mp
TMP
System Variables
JAVA
C:\Program Files\Java\jre7\bin
I am running the appllication using admin account.
The latest bitlocker file has the following information
Log started 10/17/2012 at 12:53:20
I have the latest version of java (JAva version 7 ) installed on my
computer. Has anyone encountered similar problem ?
Please help if you have a solution.
Celestine
Unsubscribe: opendatakit...@**googlegroups.**com
Options: http://groups.google.com/group/opendatakit?hl=enhttp://groups.google.com/group/opendatakit?hl=en
mitche...@gmail.com
