I used ODK collect 1.2 to upload data to Aggregate 1.4.1. In the past, I have always been able to preview the data by selecting the desired form from Submissions: filter submissions: form . But with my latest survey the data doesn't show up. The data does appear as it should when I export the file to csv. Any suggestions to fix this problem?
This isn't really a development/coding question so I'm moving it to
the community list.
Any chance you have applied filters to the data? If you have, those
filters might be hiding the data.
Assuming the data you have isn't private, the best way to get help
from the list is maybe to upload a screenshot of what you see when you
log into Aggregate.
If you do not have any filter condition set, do you see the submission?
Does the submission appear under Form Management / Submission Admin ?
If so, then that your form had a media capture (audio, video, image) that
was not successfully transmitted to ODK Aggregate.
In these cases, the submission will remain on the Submission Admin tab
until you re-upload the submission and the media file becomes available.
Once that happens, the submission will then appear on your submissions tab.
On Wed, Mar 12, 2014 at 4:40 PM, Yaw Anokwa wrote:
Laura,
the community list.
log into Aggregate.
