So I'm trying to extend the functionality of the 'Upload users and
capabilities .csv'. To test if I can make changes I changed the HTML text
of the change password popup to '(Added Text) Change password for '. For
some reason when I make this change the website won't load. The build
completes and everything. As soon as I remove the added text and set the
field value back to default everything works perfectly.
Any idea why this might be happening? Am I missing some kind of step?
Nevermind, it's working now for some unknown reason.
On Tuesday, April 11, 2017 at 11:44:45 AM UTC+2, Johann van Eeden wrote:
> Hi all
> Thanks
(1) You forgot to GWT compile and refresh the project.
(2) Eclipse does not always publish changes to the server if using Tomcat.
This is seemingly random. If you blow away the published content, it also
doesn't always fully republish it, so there is no always-works work-around
for this.
(3) Your browser may be caching the compiled GWT javascript and therefore
not render with the new JS. To avoid this, always test in an incognito
window.
Hi all
