HI,
I am upgrading odk Aggregate from v1.5.0 to v1.6.1 with my existing Apache Tomcat v6.0.
When i putt ODKAggregate war to webapps folder of Tomcat 6.0 it's did not properly extracted.
Any suggestion/solution will be highly appreciated.
Regards,
HI,
Regards,
Hi, @tasadduq786!
Could you confirm your Tomcat version? Aggregate requires an Apache Tomcat 8 or greater.
Also, normally, you would require to restart the tomcat server to get it to explode the war file. Can you try that?
Thanks..
I restart tomcat any time but can't succeeded.
My tomcat version is 6.0.
Regards,
Hi @tasadduq786
This link https://docs.opendatakit.org/aggregate-tomcat/ has very useful information regarding aggregate installation.
Try to read it though, you will learn alot in there.
With upgrade process you need to be very careful.
Thanks.
i can update my existing tomcat v 6.0 with tomcat v8.0?
regards,
Yes, it is just a program, with proper expertise you can do that.
OK,i will try to upgrade tomcat to latest version.
I am very grateful to you.
