ODK ApllicationDesigner
Hey to all, I need help with ODk application designer. I have followed the
instructions from the site
https://opendatakit.org/use/getting-started-rev126/ and in the final step
trying to deploy to my android device using the command grunt
adbpush-tables-app.
But I keep getting the following error: device not found.
Attached is the image.
Please help with this.
What do you see when you run "adb devices"? I imagine you won't see any
devices attached. You need to get adb to recognize your device before
running the grunt command.
Make sure developer mode is turned on on your phone, you've enabled usb
debugging, and have checked the popup dialog that you trust your computer.
If that still doesn't work, you might have to google about your particular
set up and how to get adb to recognize your device.
You need to get to the point that "adb devices" shows your phone, then run
the grunt command again.
step trying to deploy to my android device using the command grunt
adbpush-tables-app.
"ODK Developers" group.
