ODK begin repeat and group
Hello All,
I am new to ODK work, I need some help with repeat!!!
I wanted to repeat a group of fields based on pre-determined value, so is
it right to nest begin group inside repeat loop, please give me an example.
Thanks All :slight_smile:
-Hanan
Here is an example on how to use the begin repeat group: https://opendatakit.org/use/xlsform/
open the link and then look for the link inside which says sample excel file. Inside you have multiple examples. But, to answer your questions I do not think you can nest a repeat in a begin group. When you begin a group you have to end it then also when you open a repeat group you have to end it.
I hope it helps, if anything i said is wrong i hope someone can correct.
cheers,
Rayana
路路路 On Monday, June 22, 2015 at 10:10:33 PM UTC+1, Hanan Aqilan wrote: > Hello All, > > > I am new to ODK work, I need some help with repeat!!! > > > > I wanted to repeat a group of fields based on pre-determined value, so is it right to nest begin group inside repeat loop, please give me an example. > > > > > Thanks All :) > -Hanan
Hanan,
You can put a group (e.g., a field-list) inside a repeat. Try the
examples Rayana linked to.
路路路 -- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.
cheers,
Rayana
Hello All,
-Hanan
