I have a project well setup using ODK aggreagate as a server, ODK collect
as a mobile interface for collecting data and ODK briefcase for data pull
and export to CSV file. The new ODK briefcase uses a new command line
interface rather than the previous graphic user interface which I am not
familiar with particularly how to use the command line/the terminal to
automate data pull and export. Anyone with a clue please or any
application that can be used to interact with ODK aggregate alternative to
ODK briefcase.
ODK Briefcase still has a graphical user interface.
Double-click the file you installed to start. If that fails, try
running 'java -jar path_to_jar' from the command line.
I have a project well setup using ODK aggreagate as a server, ODK collect as
a mobile interface for collecting data and ODK briefcase for data pull and
export to CSV file. The new ODK briefcase uses a new command line interface
rather than the previous graphic user interface which I am not familiar with
particularly how to use the command line/the terminal to automate data pull
and export. Anyone with a clue please or any application that can be used
to interact with ODK aggregate alternative to ODK briefcase.
