Hello.
I'm using ODK Briefcase v1.0.2.1 (ODK_Briefcase_1.0.2.1.jar) to pull and
export submissions for a form that uses repeated groups (Briefcase's
ability to preserve relationships is important here). In ODK Aggregate,
from the bulk CSV export I can see that I have, at one time, 207 form
submissions. However, when I use ODK Briefcase to Pull these instances, I
only get 100, hence the log (in "Details..." under the "Pull" tab):
Fetching form definition
Fetching form manifest
(getting 1 of 1 media files)
preparing to retrieve instance data
retrieving next chunk of instances from server...
fetching instance 1 ...
fetching instance 2 ...
fetching instance 3 ...
[MY EDIT: continues fetching instances 4 through 96]
fetching instance 97 ...
fetching instance 98 ...
fetching instance 99 ...
fetching instance 100 ...
SUCCESS!
Indeed, in the "ODK Briefcase Storage" there are only 100 instances; same
as in the export from ODK Briefcase. How do I get the remaining instances?
Thanks!
I filed an issue on our issue tracking list. Star it to get email updates.
http://code.google.com/p/opendatakit/issues/detail?id=614
I doubt anyone will have time to look at this before next week.
Waylon
On Fri, Jun 22, 2012 at 10:37 AM, Arthur wrote:
> Hello.
> export submissions for a form that uses repeated groups (Briefcase's ability
> to preserve relationships is important here). In ODK Aggregate, from the
> bulk CSV export I can see that I have, at one time, 207 form submissions.
> However, when I use ODK Briefcase to Pull these instances, I only get 100,
> SUCCESS!
> Indeed, in the "ODK Briefcase Storage" there are only 100 instances; same as
> Thanks!
