When I attempt to run the executable JAR file for ODK Briefcase v 1.13.0, it writes a text file to my computer entitled "briefcase", but the program itself does not run. I am using Windows 10 Home on an HP Spectre laptop.
I have restarted my computer, removed the older version of ODK Briefcase (1.12.??), removed the ODK Briefcase Storage folder from the older version, scanned the executable JAR file for errors, restarted my computer again, and removed and redownloaded ODK Briefcase 1.13.0. It still writes an error log and does not run.
The body of the error log:
2018-11-30 11:40:15,181 [main] ERROR org.opendatakit.briefcase.Launcher - Error
java.lang.ExceptionInInitializerError: null
at javax.crypto.JceSecurityManager.(JceSecurityManager.java:65)
at javax.crypto.Cipher.getConfiguredPermission(Cipher.java:2586)
at javax.crypto.Cipher.getMaxAllowedKeyLength(Cipher.java:2610)
at sun.security.ssl.CipherSuite$BulkCipher.isUnlimited(Unknown Source)
at sun.security.ssl.CipherSuite$BulkCipher.(Unknown Source)
at sun.security.ssl.CipherSuite.(Unknown Source)
at sun.security.ssl.SSLContextImpl.getApplicableCipherSuiteList(Unknown Source)
at sun.security.ssl.SSLContextImpl.access$100(Unknown Source)
at sun.security.ssl.SSLContextImpl$AbstractTLSContext.(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at java.security.Provider$Service.getImplClass(Unknown Source)
at java.security.Provider$Service.newInstance(Unknown Source)
at sun.security.jca.GetInstance.getInstance(Unknown Source)
at javax.net.ssl.SSLContext.getInstance(Unknown Source)
at org.apache.http.ssl.SSLContexts.createDefault(SSLContexts.java:51)
at org.apache.http.conn.ssl.SSLConnectionSocketFactory.getSocketFactory(SSLConnectionSocketFactory.java:174)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.getDefaultRegistry(PoolingHttpClientConnectionManager.java:114)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.(PoolingHttpClientConnectionManager.java:121)
at com.brsanthu.googleanalytics.httpclient.ApacheHttpClientImpl.createHttpClient(ApacheHttpClientImpl.java:52)
at com.brsanthu.googleanalytics.httpclient.ApacheHttpClientImpl.(ApacheHttpClientImpl.java:39)
at com.brsanthu.googleanalytics.GoogleAnalyticsBuilder.createHttpClient(GoogleAnalyticsBuilder.java:75)
at com.brsanthu.googleanalytics.GoogleAnalyticsBuilder.build(GoogleAnalyticsBuilder.java:67)
at org.opendatakit.briefcase.ui.reused.Analytics.from(Analytics.java:55)
at org.opendatakit.briefcase.ui.MainBriefcaseWindow.(MainBriefcaseWindow.java:96)
at org.opendatakit.briefcase.ui.MainBriefcaseWindow.launchGUI(MainBriefcaseWindow.java:77)
at org.opendatakit.briefcase.Launcher.lambda$main$0(Launcher.java:67)
at org.opendatakit.common.cli.Cli.lambda$run$5(Cli.java:136)
at java.lang.Iterable.forEach(Unknown Source)
at org.opendatakit.common.cli.Cli.run(Cli.java:136)
at org.opendatakit.briefcase.Launcher.main(Launcher.java:79)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)
Caused by: java.lang.SecurityException: Can not initialize cryptographic mechanism
at javax.crypto.JceSecurity.(JceSecurity.java:93)
... 37 common frames omitted
Caused by: java.lang.SecurityException: The jurisdiction policy files are not signed by the expected signer! (Policy files are specific per major JDK release.Ensure the correct version is installed.)
at javax.crypto.JarVerifier.verifyPolicySigned(JarVerifier.java:328)
at javax.crypto.JceSecurity.loadPolicies(JceSecurity.java:378)
at javax.crypto.JceSecurity.setupJurisdictionPolicies(JceSecurity.java:323)
at javax.crypto.JceSecurity.access$000(JceSecurity.java:50)
at javax.crypto.JceSecurity$1.run(JceSecurity.java:85)
at java.security.AccessController.doPrivileged(Native Method)
at javax.crypto.JceSecurity.(JceSecurity.java:82)
2018-11-30 11:41:39,640 [main] ERROR org.opendatakit.briefcase.Launcher - Error
