I tried to use this briefcase version on a 1.4.12 ODK Aggregate server to download a form that has a couple of repeats.
This works perfectly with the previous version of Briefcase.
Now with this version when I try the export I get an error (see attached log).
briefcase.zip (1.0 KB)
If you need I can forward you the pulled submissions privately.
Aurelio
I'll try to reproduce the issue on Windows, just in case
Thanks, @aurdipas ! I'll take a look to the issue you're reporting today
I've filed a fix for what @aurdipas is reporting https://github.com/opendatakit/briefcase/pull/760
We had an issue under particular encofings of time zone offsets in time field values.
Hi, @rassam !
I've reproduced the problem you're reporting on a Windows 10. I'll try to do something about it.
Hi, @rassam !
It's kind of hard to track how encoding works when dealing with Briefcase and other apps in Windows, but I wanted to try forcing Briefcase to read the pulled submissions using UTF-8 and I got some confusing results. Here's a screenshot:
You can see here:
The Windows notepad app can open the exported file and shows (hopefully correct arabic characters.
The powershell terminal doesn't show arabic characters
The bash (emulated Linux on Windows) doesn't show arabic characters
This one is particularly confusing because I verified that I was using the same locale as in my main Ubuntu machine
The blanks might be telling us that the arabic characters are there but the font I'm using doesn't have them, although I can't be sure.
OK, false alarm: I copied the exported file to my Ubuntu machine and now the arabic characters are there.
This proves that we can improve Briefcase. I'll file an issue and, hopefully, it should be released in v1.16.1 tomorrow
getodk:master
← ggalmazor:issue_761_force_utf8_encoding_while_reading_http_entities_into_xml
opened 11:21AM - 10 Jul 19 UTC
Closes #761
#### What has been done to verify that this works as intended?
M… anually tested on a Windows 10 machine using the form attached to the issue
Manually tested on Linux to ensure that it still worked as expected on another system.
#### Why is this the best possible solution? Were any other approaches considered?
This is a narrow fix and I didn't consider any other approach.
#### How does this change affect users? Describe intentional changes to behavior and behavior that could have accidentally been affected by code changes. In other words, what are the regression risks?
It feels like it's a safe change with no risk of affecting in an unpredictable manner.
#### Does this change require updates to documentation? If so, please file an issue at https://github.com/opendatakit/docs/issues/new and include the link below.
Nope.
rassam
July 10, 2019, 1:22pm
27
Hi, @ggalmazor
Great!
Thanks for your valuable support
Heads up, @rassam , @aurdipas ! We've just released Briefcase v1.16.1 with the fix for the issues you have reported. Thanks for your help!!
