Hi, I am using ODK Briefcase V1.0 Beta 2.1 is there any way to get it
to work through a Proxy?
Thanks GISTIN
What difficulties are you having? It should work fine through a proxy.
FYI: I'm aiming to have a 1.0 Production version, or, at least, a 1.0
Release Candidate, out by Monday.
On Thu, Jan 26, 2012 at 7:46 AM, gistin wrote:Hi, I am using ODK Briefcase V1.0 Beta 2.1 is there any way to get it
Thanks GISTIN--
I can connect easily through home or wifi connection, but I get the
following error from work machine (which uses Proxy).
[image: image.png]
GISTIN
On 26 January 2012 16:49, Mitch S wrote:What difficulties are you having? It should work fine through a proxy.
Release Candidate, out by Monday.Mitch
Thanks GISTIN--
mitchellsundt@gmail.com--
Curious. Unfortunately, I have negligible experience with proxies.
Can you see http://opendatakit.appspot.com from work?
It might be that your proxy has port 80 configured, but not port 443
(https).
Or perhaps a different browser may have a more complete proxy settings
configuration. Your network admin should be able to help.
On Fri, Jan 27, 2012 at 2:16 AM, J Moat wrote:I can connect easily through home or wifi connection, but I get the
following error from work machine (which uses Proxy).[image: image.png]
GISTIN
Thanks GISTIN--
