My Briefcase has been giving me troubles in the last couple of days. At the
moment it doesnt even open, I have tried replacing it with newer versions
but still no difference.
Can I find any other tool that works like briefcase? Or is there a way I
can download forms with repeat group without using the briefcase?
Kindly help.
Warm regards
Hi Tony,
What, if anything, has changed on your computer since the problem
started happening?
What operating system (and version number), version of Java, and
version of Briefcase are you using?
When you say it doesn't even open, what happens exactly? Explain it
like I'm 5
> Can I find any other tool that works like briefcase? Or is there a way I can
> Kindly help.
> Warm regards
> "ODK Community" group.
Hey Yaw
I have been using "ODK Briefcase v1.4.5 Production" for over two years now.
But I have also tried V1.4.10 but still doesnt open. The odk briefcase
doesnt open at all.
What do you think might be the issue here?
On Wednesday, March 22, 2017 at 3:08:43 AM UTC+3, Yaw Anokwa wrote:
> Hi Tony,
> started happening?
> like I'm 5 :)
> Yaw
> the
> versions
> can
> > Kindly help.
> > Warm regards
> Groups
> an
Hi Tony,
For me to help, I need answers to the questions I asked earlier.
started happening?
What operating system (and version number) and version of Java are you
using? https://www.java.com/en/download/help/version_manual.xml might
help here.
When you say it doesn't even open, what happens exactly? If it's hard
to describe, download http://www.cockos.com/licecap, record the steps
you are taking, upload it to http://imgur.com and post a link.
On Wed, Mar 22, 2017 at 2:15 AM, Tony Henry wrote:
> Hey Yaw
> doesnt open at all.
>> Hi Tony,
>> started happening?
>> like I'm 5 :)
>> Yaw
>> > the
>> > versions
>> > can
>> > Kindly help.
>> > Warm regards
>> > Groups
>> > an
>> > email to opendatakit...@googlegroups.com.
