andrew,
the form works for me, so something is likely corrupt with your odk
folder on the sdcard. read over the following steps, then try it out.
you will lose all your forms and data when you do these steps, so if
you need that data, please back up that folder or submit them to your
aggregate install.
- make sure you quit odk collect.
- delete the /odk folder from your phone's sd card.
- unplug your phone from the computer (or any device that might mount
the sdcard) - reboot the phone.
- relaunch collect and try the new form.
in the future, please send such questions to the mailing list (cc'ed).
we prefer you use the mailing list because it reduces duplication and
allows the entire community to answer questions in a publicly viewable
and searchable way.
yaw
