I have constructed a form using ODKBuild. When I export to .xml and upload to ODK aggregate, I receive the following message:
"Error: Problem with JavaRosa Parsing Form: org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: Javarosa failed to construct a FormDef. Is this an XForm definition?"
Also, when I use the upload form function in ODKBuild, I receive a similar message
"Could not upload the form. Aggregate could not validate the form contents. Please make sure your form is valid and try again."
I am using ODK Build and ODKAggregate on a Google Cloud Platform - App Engine Release 1.9.54. My laptop operating system is Linux Mint 17.1 Cinnamon 64 bit
I would like to attach the xml file but am unable to as a new user. However, I have uploaded the xlsx file to google drive - please check out this link: https://docs.google.com/a/plaas.org.za/spreadsheets/d/1xcXiFu8-19MMtLwEev76hHlwRnGDRKlyhLwE3fPo2gs/edit?usp=sharing
I have tried to remove any cascading questions and have double-checked the "relevance" function - still can't figure it out.
